Illum
Someone needs to do a "long term abuse" test.
I'm not impressed by "tests" that consist of dropping a flashlight 30 feet onto concrete or throwing the light against a brick wall.
What I want to see:
A light in a cement mixer just filled with sand or small rocks for a period of 7 straight days.
A light last 20 continuous wash and dry cycles.
A light frozen, then dropped into warm water for a dozen or so cycles.
A light dragged behind a bicycle for 50 miles
A light in 12 inches of water for 28 days
A light on the dashboard of a car driven in a climate where it regularly gets above 85 (F) in the summer and below 30 (F) in the winter for a period of 5 years.
You get the idea...
When you see your light dropped, run over by a car, hit by a bullet, etc. you immediately know it might be broken or is about to completely break. However, long term, repetitive shock/impact/friction/temperature changes, etc. will really test a light as I believe many unexpected failures occur under relatively moderate, constant abuse - not some rare, freak occurrence.
your not going to like the results.....
I don't think current flashlights can win an iron"light" contest...especially ones with complex switch assemblies and nature of deterioration that exist in both incandescent and LED alike
testing such as A light frozen, then dropped into warm water for a dozen or so cycles. paired with A light last 20 continuous wash and dry cycles. or A light frozen, then dropped into warm water for a dozen or so cycles. or A light in 12 inches of water for 28 days probably won't last too long given the durability of o-rings:devil:
but I agree, long term abuse is usually more accurate in testing of durability of lights
