Got it today :twothumbs
However there wasn't a user manual for the M14
They said it was a "known issue" with the UK package. I don't see a need to return it but I will try to see if I can hunt one - either English or German - either is fine with me.
Hey I even got a very low twin prime serial number! :naughty:
Haven't done any long tests to can't comment on that yet.
Flood is very nice. Spot is... well very spotty
Approx. the size of the spot in Fenix TK20 but much more intense as it's lens can direct most of the spill too. Can be I do some measurements in the near future when I get some time.
UI is quite nice too and rather unique. It's sort of a mix between forward and reverse click. From off press to momentary on (with 130%) and you may morse with it if you want. Press and click and it'll turn up in 100% mode. Actually subjective there's only a very thin hair of difference between 100 and 130% - just as expected. While on you can soft click like a reverse click to advance modes. When in 100% mode and you press and hold (still a soft click) the light fades slowly in and out between 100 and 15% or so. Release at the wanted level.
To sum up. Practically all the positives of both forward and reverse click almost without their drawbacks - very nice!
It uses PWM regulation for dimming. But at a very high frequency (tint don't change like PD20). My guess would be around 5-10 kHz based on the sound I hear by lighting on a solar cell connected to some earphones.
Just for fun I bought the M1 too. A simple single CR123A based one with 100%, 15% and strobe - only a little bit longer than the Fenix PD20 (Q5). Despite being rated lower lumen wise it's noticeable brighter than my Q5 PD20 (or LD20 as they're practically the same). Again nice flood to a tight spot. Although not as tight as the M14 naturally but still no problem out throwing PD/LD20.
The M1 is a forward click. Wonder why they chose that. It would have benefited more from a reverse click as it's driver is like the typical driver without memory - short power interruption to move to next mode.
M1 uses PWM regulation too. Not as high frequency but IMHO high enough not to be an annoying (unlike Fenix LD01/05, MiniM*g Rebel and many DX lights etc.).
So far I'm quite impressed with the lights. My only fear is the lenses is made of plastic not glass - wonder how's the best way to clean them when they get too dirty.
