Scattergun
- Joined
- May 9, 2006
- Messages
- 485
If going with a single 18650 the GD1000 is a bit overkill! Just buy an AMC7135 and run it at 1000 or 1400 mA! A lot cheaper, and very robust solution!
Allrighty, I finally have most of the parts and I'm just waiting on the heatsync now. So anyone care to comment on the LED? I have an XR-E R2 and an XM-L T6. I know the XM-L is brighter, but will it make a better thrower than the R2? If it's going to be comparable because of the surface brightness of the R2, then I would probably go with the R2 because I'd be running it at 1400mA instead of 3000mA (with the XM-L).
Whichever one is the better thrower is the one I want to go with...
It depends on how hard you drive the XM-L. I have three Mag 2D lights, all with the same DX 12834 aspheric lenses and the LEDs recessed into the neck for perfect focus. One is an XM-L overdriven to 5.0A, one is an SST-90 driven to 7.5A and the last is an XR-E slightly over driven by the old KD drop-in. The XM-L is the champ of the three. Compared side-by-side, it's die image is brighter (and bigger) than the XR-E. The SST-90 is the largest and casts the most light, but it's not the brightest of them. As far as throw goes, if I could find a distance great enough to test, I'm sure the XM-L would win, however, I've never travelled with them and the furthest tree top that I have line of sight to from my house is only ~500 ft. away and they all do an excellent job of lighting up the foliage.
Based solely on your 3*NiMH power supply, I recommend the XM-L because it has the lowest Vf and will be very easy to regulate to a very high current for a long time. I recommend beginning with a 2.8A 8*7135 regulator and once you're satisfied that your heatsinking is good enough, you can slave an additional 1.4A regulator for a total of 4.2A. You will NOT be disappointed.
I actually wound up buying a Grey 2D krypton mag for the host. I made up a (2)D to (1) 18650 battery convertor, so that's what I'll be using. I have (1) 5-Mode 2.8A driver, (3) 1.4A drivers, and (1) 1A driver.
I think I should be able to use the (3) 1.4A drivers as you suggest. Do you just wire them in Parallel to the XM-L (or do you put them in series, I don't know anything about driver sandwiching)? Do they all need to be potted together? I guess I need to put insulative material in between all of them? If I'm going to be running at 4.2A, I'm probably going to need to make it (2) 18650 in parallel.
