mcnair55
After buying them a couple of years back and using them, they are ok but i will not be buying any more would rather spend the extra on Eneloop.
I also recently bought some of the (new?) Lidl Tronic Eco LSD batteries that are shown in Tinderbox's post above; I got a pack each of AA & AAA. As I couldn't find any testing on them I thought I'd have a go, as I've been helped a lot by similar tests here & elsewhere in the past. Although by the time I've finished Lidl will probably have sold out! I must stress I'm no expert, so please be gentle with comments! Also not sure if this warrants a whole new thread?
I have an AccuPower IQ-328 charger which I'm still getting used to (incidentally does anyone know if there's a way on this unit to just measure how much juice a battery has left without actually dis/charging?) so again you'll need to bear with me as far as technical info goes.
So the AAAs first...
The pack states 950mAh, and that "Batteries require approx. 5 charge cycles to reach full charge capacity", as I said I don't know how to just measure existing / initial power, so ran them through a discharge / charge cycle at 250 / 500 mA. When the unit displayed 'Full', the results showed:
Battery 1 - 900 mAh
Battery 2 - 955 mAh
Battery 3 - 984 mAh
Battery 4 - 944 mAh
Now as a novice I was a bit surprised at these results - they sound a bit too good to be true? But I'd be interested to hear others' thoughts...
I carried on with three more discharge / charge cycles, to see how the results progressed, and there were a few oddities...
Battery 1 - 889 / 845 / 896 mAh
Battery 2 - 978 / 1007 / 994 mAh
Battery 3 - 1057 / 1300* / 994 mAh
Battery 4 - 942 / 982 / 962 mAh
So you can see that some went down then up, some went up then down, and one (marked with a *) showed no sign of stopping, just kept rising until I decided to pull the plug - I'm guessing this was a random charger glitch, rather than a cell issue...?? At no point were they showing any signs of overheating, in fact they were all just room temperature.
I'll run some more cycles, and try to use them in some devices, and post more findings soon. Also will do the same with the AAs (rated 2300 mAh), just running first cycle now and the results so far are -
Battery 1 - 2300 mAh
Battery 2 - 2510 mAh
Battery 3 - 2600 mAh (and still rising...)
Battery 4 - 2420 mAh
Cheers - Jos
I have been using the RED Lidl rechargeable battery`s for a few years now, and have had no problems, hopefully these ones will be the save, Eneloops are more than double the price of these in the UK
John.
It is all very well doing tests but nothing like using them in real life and to be honest they are not worth the money as there length of working service is dire.
Unfortunately, that tells us something about those cells bought a couple of years back, not about what Lidl is selling now.After buying them a couple of years back and using them, they are ok but i will not be buying any more would rather spend the extra on Eneloop.
Same thing: either you're talking about cells that were on the market years ago (which doesn't help to determine how good/bad currently sold cells are). Or you're talking about currently sold cells, read: you can't make a fact-based statement about their service life - yet. Unless it's so bad it shows after just a few cycles.It is all very well doing tests but nothing like using them in real life and to be honest they are not worth the money as there length of working service is dire.
I bought a pack of AAA's (rated 950 mAh) and 9V block (200 mAh), and 3 packs of the 2300 mAh AA "Tronic eco" shown above, especially to replace alkalines in rarely used / low-drain devices. Like the myriad of 1x AA quartz clocks in our house. If they are indeed LSD cells (looks that way ), and @ just 1 Euro/cell, very few recharge cycles would do to start saving money. And no need to run out & buy new pack of AA batteries all the time! For that purpose they've done fine so far. Given their price I don't expect much, so (to me) any other uses for which they proof suitable are a bonus. I've also got a pack of non-LSD AA's which Lidl sold recently (different color labeling/packaging), which I only bought for comparison and tbh expect to be utter trash. :devil:
Some months ago there were similar looking LSD NiMH's for sale at Lidl. Which IIRC had slightly lower mAh ratings, and some very minor differences in the labeling. All of these "Tronic eco" cells that I've seen, have a production year/month printed on them. These 2300 mAh AA's have the name of a German company on them (EURES GmbH), which I suspect is just rebadging/packaging cells produced by a 3rd party. So it's anyone's guess who produced the actual cells. :thinking:
Funny thing is, none of these Tronic cells fit into a 2x AA flashlight I also bought @ Lidl recently... :hahaha:
My earlier suspicion confirmed... A pack of the red Tronics I bought for comparison (2500 mAh), were shelved fully charged. Just 3 weeks later, less than half charged. So self-discharge is annoyingly high on these red Tronics.And ehm... don't confuse with the red Tronics - totally different beast.
Another data point concerning Lidl's "Tronic eco" AA 2300 mAh: (the green/black labeled ones, pictured earlier in this thread)
So far they've worked fine for me capacity-wise. BUT... some time ago my gf had a pair in a digital camera, and it wouldn't power up (or rather: showed "replace battery" when done so). At the time I ignored it as 'probably forgot to charge before use'.
But today I saw the same thing with a pair of these Tronic eco's, which I know had been charged about 1 month ago, and sat unused since then. A pair of Eneloops charged around the same time, worked fine. Also (afaict) these Tronic eco's do hold their charge in the low-self-discharge sense.
Conclusion: seem to be okay so far capacity and self-discharge wise, but high-current capability might not be good. Sorry... can't be bothered to try and do some measurements on this. Just giving you peeps the heads-up.
P.S. There's also 2100 mAh's out there, which might not be the same thing. And ehm... don't confuse with the red Tronics - totally different beast.
I just had my camera reject my trusty and surprisingly working Duracell 2650's. They were right out of the charger too. These batteries work fine in anything else I put them in. Perhaps cameras are unusually sensitive. My camera works fine with eneloops, Duracell 2450's and duraloops. But it wouldn't power up with the 2650's.
