LiFePO4 starter battery
orbital
WI
Looking for any input and experiences with them.
Good/bad/anything
The higher voltage is a small concern, but using below 32F could be an issue.
thanks in advance
orbital
WI
My interest is in powersports size battery (motorcycle)
AGM batteries have been such a hassle in my life, not totally sure how to begin describing it.
In '23 alone, two absolute failures since late April, that's enough for me.
When I said voltage could be a concern ^ I was referring to charging system on a bike not being quite enough for LFP.
BVH
CentCalCoast
What is the maximum charging system Voltage on your bike? There is almost no usable capacity to be gained when charging over 3.5 Volts per cell or 14 Volts. I charge all my LFP's to only 3.5 VPC so if your bike reaches 14, you're good to go, Voltage wise.
orbital
WI
What is the maximum charging system Voltage on your bike? .
It's 13V +- .1
was a bit frazzled yesterday, my battery just imploded about 30 min. from my house.
I keep a 3S Lipo with me for emergencies, clamped it on = just got me home.
just a quick note:: if something you own is running really bad, thinking it's the carb/motor and you don't have a voltage number,
it could be just a bad battery.
You wouldn't believe how terrible something runs when the battery is ☠️.
Simply have to test this for $53
KITROBASKIN
New Mexico, USA
Guessing you would be able to bring the battery inside during below freezing weather? Does the manufacturer of that Amazon battery have cautions about sub-freezing events?
jzchen
Arcadia, CA
Can also search YTZ7S LiFePO4 on eBay. I have been buying the "Dohon" ones there for a while now for vehicles in the household. At least with those 13.0 - 15.0 V is okay. Don't have experience with them in the COLD I'm afraid…
orbital
WI
What charger are you using?
_____________
add: clamping on a 4S lipo with voltage at around 14.8V will add voltage to a AMG or lithium in a pinch.
just positive to positive // negative to negative
jzchen
Arcadia, CA
When my first one arrived it came with a small instruction booklet. It says to verify the alternator output is within that range. Most vehicle output is within that range. I use any charger with a Li mode, manufacturer recommends fixed voltage charging @ 14.6 V. My first one in our 2012 Prius v is over 4 years old…
