Light Review: Streamlight Dualie – 3AA Magnet, 2AA ATEX and Laser ATEX
subwoofer
Hove, UK
Streamlight's Dualie range are not the only dual-beam lights available, so might look familiar. The 3AA version is not new, but the 2AA ATEX and 3AA Laser ATEX are both recent additions for Streamlight, adding more options to this Intrinsically Safe range.
Taking a more detailed look at the Dualie 2AA ATEX:
We are starting with a detailed look at the 2AA ATEX version, but before we do, here are all three Dualie lights on test in this review. The 2AA model arrives in a cardboard box like the 3AA Magnet, with the 3AA Laser in a plastic blister pack.
In the 2AA's box along with the Dualie is a set of alkaline batteries, a wrist lanyard, an Allen key and the instructions.
Immediately striking is the offset head design of the 2AA.
And this is why it is a Dualie. The flood-light LED in the side of the head.
A better look at that unusual offset battery tube. The top of the pocket clip is kept level with the line of the head of the light.
The tail has a lanyard hole, and also a magnet.
A simple, deep, steel pocket clip is fitted to the 2AA.
The main beam's switch is the largest, and has a checkered grip pattern.
A close look at the 2AA's main-beam reflector and LED.
The same LED is used for the side mounted flood beam without any reflector. The side beam's switch is smaller and has no checkering.
Inside the light's head are two contacts made from coiled wire.
The coil contacts connect to the battery positive terminal and a contact built-in to the front of the battery tube. The other metal part visible here is the locking screw to fix the head in place.
Instead of screw-threads, the 2AA uses a bayonet fixing for the head / battery tube fitting.
The batteries are now fitted into the body.
Now we see why there is an Allen key included. With the head fitted back onto the body, the locking screw can be tightened.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
Taking a more detailed look at the Dualie 3AA Magnet:
In the 3AA Magnet's box along with the Dualie is a set of alkaline batteries, a wrist lanyard, and the instructions.
The Dualie 3AA Magnet's name is due to the two powerful magnets that have been added for more hands free options.
Not ATEX rated, but still intrinsically safe.
One of the magnets is in the very end of the tail which is part of the extended clip.
The other magnet is in the side of the clip.
The clip extension also acts as a hook.
The main beam's switch is the largest of the two, and has a checkered grip pattern.
For the flood beam on the side there is a second slightly smaller switch which also has a checkered grip pattern.
Looking into the main beam's reflector and its LED.
A full exposed LED with no reflector provides the flood beam.
To access the battery caddy, the bezel unscrews from the front of the head.
This then allows the main assembly / battery caddy to slide out of the body.
It is a self contained unit with reflector, LEDs, switches, and battery holders.
Each cell holder has spring contacts for the negative terminals.
Plus a coiled positive terminal.
Two cells are fitted to one side, and a single cell into the other.
The threads for the bezel ring are moulded plastic.
Off to work we go.
Taking a more detailed look at the Dualie Laser ATEX:
In the 3AA Laser's packaging, along with the Dualie is a set of alkaline batteries, an Allen key and the instructions.
It the case of the 3AA Laser, the second beam is a red laser. Intended as a safe 'pointer' for communicating clearly what is being discussed in industrial environments.
No mistaking what added feature this light has.
Intrinsically safe and ATEX rated. You might spot one of the ATEX requirements.
I was of course referring to the locking screw.
What would have been the window for the flood beam on other Dualie models is covered with a laser warning sticker.
As the laser needs to be projected forwards like the main beam, the main beam's reflector has been modified with a hole for the laser to shine through.
Another view of the hole for the laser.
As the main purpose of the Laser model is to provide a safe pointer, the clip is a shorter version than on the Magnet model.
Just as with the previous 3AA model, there is a self contained assembly that is removed from the body which contains all the workings of the light.
Threads are moulded into the plastic body for the removable lens bevel.
The beam
With three lights, all with dual functions, there are several beam-shots to look at.
First up are the main beams of each and the 3AA Magnet.
Next is the main beam of the 3AA Laser oddly, though its lumen output is virtually identical it appears brighter despite an identical exposure.
The 2AA's main beam has a much wider spill than the 3AA models, but is noticeably dimmer.
Secondary beams:
Now moving outdoors:
Modes and User Interface:
Operating the Dualie lights is as simple as it gets. Each of the two modes available in each light has its own switch. They can be used independently or together.
The main beam switch is a forward-click momentary type switch, and the secondary side beam switch is a reverse-click type.
Batteries and output:
The naming of each Dualie means there are no surprises that the 2AA runs on 2AA cells (alkaline or NiMh) and the 3AA runs on 3AA cells (alkaline or NiMh). The Laser is bases on the 3AA so runs on 3AA cells (alkaline or NiMh).
___________________________________________________________________________________________________________
Dualie model and mode.I.S. measured ANSI output LumensPWM frequency or Strobe frequency (Hz)
2AA – Main1030
2AA – Flood750
2AA – Main + Flood1220
3AA – Main1420
3AA – Flood1010
3AA – Main + Flood1760
Laser – Main1470
Laser – Main + Laser1460
There is no parasitic drain.
For the runtime tests, all measurements were taken with both beams on for all models. Putting all three runtime traces on the same graph, and the lower output 2AA model takes the runtime prize, but at a much lower output.
Troubleshooting
This section is included to mention any minor niggles I come across during testing, in case the information helps anyone else.
The Streamlight Dualies in use
Before looking at any other aspect, it is important to highlight that these Dualie lights are Intrinsically Safe. That really is what it says - Intrinsically Safe devices are specifically designed to limit electrical and thermal energy that might be available for ignition. It means they are effectively incapable of igniting specific explosive atmospheres. This is why generally Intrinsically Safe lights are relatively low powered, use alkaline primary cells, and are made from plastic.
Take the most typical domestic scenario; you get back home at night and smell gas in the house. You need light to find the main gas valve (which is in a cupboard) and to get to windows to air your home. Don't touch that light switch, so what can you use in confidence? An intrinsically safe light specifically designed to be safe to operate in explosive atmospheres of course. As long as you check the certification matches the possible hazard (for example the 3AA Magnet says it is certified for methane / air mixtures only) before you really need it.
I keep a couple of Intrinsically Safe lights in the hall sideboard so I can get my hands on one straight away. I also keep a suitably rated one in the car and in the garage in case of fuel spillages.
Personally, as I don't work in explosive atmospheres, I mostly keep Intrinsically Safe lights as standby backup lights rather than everyday use ones, but generally always have one close by. If you need this type of light for work, then you will know the regulations and exactly what your requirements are.
What is not clearly shown in the beamshots, is that there is an uneven corona around the hotspot with visible yellowing, they are definitely not the cleanest of beams. This doesn't truly impact on their use, as it is only when you are white wall hunting and looking for beam defects that you really notice them. When you are getting on with a job, it doesn't matter that much, and will be the least of your worries if you actually need their Intrinsically Safe aspect.
The magnets are strong enough in the two models that have tail magnets (the 2AA ATEX and 3AA Magnet), that they are able to hold the light at any angle. Taking the worst case, they will stick to a vertical steel surface and keep the light pointing horizontally. I've also found this to be true on steel bars as well, so not limited to flat surfaces. On the 3AA Magnet there is the additional magnet in the clip on the side of the light, providing more mounting angles. I use this side-mounted magnet for storage of the 3AA Magnet light, having it hold itself on the side of a metal cabinet ready for use.
It is important to compare like with like, and these Intrinsically Safe lights do not compete with the current Li-ion powered lights in terms of output and beam quality, but that is not a fair comparison. These are lights designed to be simple and safe to use just about anywhere. Two independent lighting functions operated by two switches, reliable and predictable AA power, light weight, tough and Intrinsically Safe. I'm certainly glad to have a few of these lights around.
Review Summary
Things I likeWhat doesn't work so well for me
Intrinsically Safe.Not the cleanest of beams.
AA powered.Switches need quite a firm press to click.
Simple to use.
Lightweight.
Reliable.
Tough.
Highly functional clips / magnets.
(Moderators, there is a reciprocal link at the end of every review on Tactical Reviews.)
thermal guy
ny
Thinking the 3AAA with side flood be great for my get home bag! Nice flood for walking.
