DM51
Sparkss has put his finger on it. You really need an IR LED, or an incan bulb. Either that, or a camera that is very, very sensitive to low levels of IR.
The problem is that regular white-light LEDs put out almost zero IR content. A filter is subtractive, which means it cuts out the light you don't want. It can't boost that part of the spectrum you DO want. So if you start out with a light source that has only 1% of its emission in the IR spectrum, putting an IR filter on it will just cut out the other 99% of colors, and you'll end up with an unworkably weak IR source.
