Looking for Flashlight recommendations...
JAXXAR
NL, Canada
Thank you Zespectre, for creating this checklist! 🙏 I've done my best to answer the questions, but please let me know if anything needs to be clarified.
Cheers
Jason
☑️= noteworthy
✔️= YES
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__✔️__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
__✔️__Up to $100. Cad 😜
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__✔️__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__✔️__SMALL - Every day carry (4-7 inches). (I think I like the range of 4-6 inches, 7" is too much)
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__✔️__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__✔️__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__✔️__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al). I'm gravitating towards the 18650, but am open to other (smaller) suggestions. I also really like the idea of being multi fuel compatible (like 14500 and AA). I am unfamiliar with protected vs unprotected batteries, and their pros/cons.
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__✔️__I want a separate/stand-alone charger (this involves removing the batteries to charge) or usb C port built into Flashlight
____I don't care
_✔️_Lets say Max Lumens can be as little as 300 or as much as 1000.
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
__✔️__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
__✔️_I'm not really sure on this one. I think Flood will be more important to me, but would like some Throw, with not too much of a "Hot focused Center".
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
__✔️__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__✔️__5-20 yards/meters (check out a noise in the backyard)
__✔️__30-50 yards/meters (I have a big backyard)
____150+ yards (I am searching from a helicopter)
Unsure on this one...
__✔️_30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__✔️__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
__✔️__I want a forward clicky (Helpful for momentary activation and signaling).
__✔️__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
__☑️__I want a body mounted switch (near the head, like on a Maglite). This would be a plus, for mode selection (in addition to tail clicky) but not mandatory.
__✔️__I want a tail mounted switch (found on the majority of today's high end lights). Tail clicky with momentary is a must.🌟
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
__☑️_Other, please specify__Any such thing as a magnetic tail clicky with momentary?😁___(I don't think I want an E-Switch?, unless I can be convinced otherwise)__.
____A simple on-off with only one output level is fine for me.
__✔️__I want multiple light levels. (Some lights have 5-16 light levels.) Mode memory would be important I think.
__☑️__I want a programmable light.
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__✔️__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
__✔️__IPX7 (Waterproof to 1 meter/30min)
__✔️__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__✔️__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
__☑️__Red filter (for preserving night vision). Would love a red filter, but not mandatory.
__☑️__Dedicated R/G/B secondary LEDs. ...for the red maybe...
____"Hybrid" light (bright incandescent combined with long running LEDs)
__✔️_Pocket/belt clip Prefer two-way/Reversible clip
__✔️_Holster This light will live on my belt, in a holster.
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
__✔️__Flashlight MUST be able to Tail-stand! 🌟
__✔️__Must have a Firefly/Moonlight mode
Thank you to anyone who takes the time to read my input, and come up with suggestions! I really appreciate it.
Cheers
Jason
NL, Canada
Columbus, Ohio
Start your evaluations with the following suggestion to see how closely they match your wish list:
1. Acebeam E70 MINI Nichia 519A flashlight.
2. FourSevens Quark QK16L flashlight (can't tailstand, but still a very well regarded light).
3. EagTac D25LC2 Clicky (multiple emitter options).
4. Malkoff M61HOT (slightly outside your stated budget, but on sale as of Feb. 3, 2023, and bombproof).
These suggestions don't meet 100% of your wish list, but outside of a custom-built light, my guess is that it's unlikely there are any production lights that do. So start with these, read the reviews, and start to get a feel for which if any will work for you.
