[ QUOTE ]
FBA said:
dabiscake,if i get a Mc module drop in , will the throw be better than the stock M6 led?
[/ QUOTE ]
IIRC, the stock Pelican M6 does use the stock Pelican reflector, correct? Then the throw of the drop-in or other PR-T options as other mentioned would be similar, if you want to get an idea, but much brighter with a Lux III driven to 1A.
Now, that's why I advocate the use of a cut-down 30mm... IMHO, this setup is on top when it comes to throw. I know a lot of people don't like the 30mm, it does have a donut hole you have to adjust to when I use it with my 5Watters, but for single die LEDs, it's a tight, bright and clean hotspot, with limited side spill. /ubbthreads/images/graemlins/thumbsup.gif
