Thanks,,,,,What were your voltages at the time periods mentioned with the VTC5 and the K'Power 3500?
Different light but same concept.This is in regards to My M2Xvn XML2 U3 PDT DD/Single Mode light. I use the VTC5 and other comparable IMR batteries. For the VTC5 AFTER 20 MINUTES the voltage is 3.72v. I would guess at that point[when I put another fresh one in] it is ~ 65/70% max output. My point being, the M30Cvn having so much more initial output[2100L to ~1200L]than the M2X,would most certainly have to be LESS than 65% initial output after 27m 45s which is almost 8 minutes longer than I run a light which demands less of the battery life.
I have the nichia 219c in my TOOLvn and love it!
At the end of either run the light is under 1000 lumen output. Start at 2100 lumens and when battery is depleted probably around 800 lumens.
