Got Lumens?
BigC,
Your pictures didn't make it. reposted for you, click thumbs for fullsize, GL
Me and BigC have recently ran into some very stuborn S12 LED. both of our most recent S12 only pull 3.5A on regulation! This is surprisingly low. I DD it and only increase to 3.8. I guess this mean not all SST-90 are equal... :-(
You need my 7A LED on that copper block! LOLVery true. My other SST-90 burn-in lights were all top bin SST-90 from cutterelectronics.com. This is my 1st production light SST-90 that I tried to burn-in and just got from 3.6A to 4A at the tail after the burn. arghhhhh They are probably low bin types, I bet!
Anyway at 4A and with my copper heatsink the light gets almost really hot at 5min anyways. So, its not like it can take anymore or my thermal path is just freaking insanely efficient.
bigC
Now I know why some people don't like their S12...I think SST-90 is the most inconsistent LED in terms on Tint and brightness.
Question...
XM-L can make 800 lumen at 3A
SST-90 make 800 Lumen at 5A
?! What the heck?
15A!?
Hadn't realised anyone was pushing them quite that hard.
Hey guys, I found out tonight that if you don't clip the black ground when you solder directly from the LED negative to the ground screw something really neat happens. You get 5-5.3A on high and YOU STILL HAVE A LOW SETTING complete with memory! The only difference is that the low goes from being about .350A to around .600-.650!
I don't know what kind of lumen this thing is putting out now but the throw picked up a bunch! Vinny, set that thing back on STUN and go check out the throw!
Maybe I should start a new thread about this. This thing is really putting out now! :devil:
Could you post some pics?Hey guys, I found out tonight that if you don't clip the black ground when you solder directly from the LED negative to the ground screw something really neat happens. You get 5-5.3A on high and YOU STILL HAVE A LOW SETTING complete with memory! The only difference is that the low goes from being about .350A to around .600-.650!
a quick question if i may, would u think it ok to burn in with 2 26650's in parallel?I saw my friend attempted and I gave up...If anyone found a super good way please post here.
Direct Drive Update:
I got the batteries from BigC and have initiated the burn in process. 4 of those little CR123 1.2 V push 8.5A at full charge. I can only burn in the light 30 seconds at a time. The lights get too hot to hold so I just want to be on the safe side. Originally an IMR 26650 push 3.8-4A Max. After 6X30sec burn in I have gotten the light to pull 4.7A! Yayyyyyyyyyy I have to recharge the batteries after 3X30sec burn in. The battereis also gets hot after the 3rd consecutive burn in. I will continue to burn in and hopefully reach 6.5A as BigC did. Pray for me ;-)
IMO This light can run reliability at 5A constantly if you hold it in your hand....The light does not get too hot to hold at 5A. Mounted on a bike being air cooled this light can be run at 6A constantly. These are just my opinions again.
