Heat was a major problem when I tried something similar in the past.
I think heat will melt the entire plastic socket. I've tried the soli with three or four lamps and everything including the overdriven mag lamp melted some part of the lens and reflector. A 10440 is just pumping out too much power to the tiny lamps. Rayovac makes a 3AA lamp that fits. Even though it is rated for 3.6 Volts it produces more heat than the soli can dissipate. And, I must add, there was a lot of light briefly (poof) but the beams were almost unusable. Some 2AA Mag lamps lasted for thirty seconds and some lasted almost two minutes.
I hope y'all have better luck than I did.
