Lord Flashlight
It's regulated to dim after a few minutes. Unless they've updated this model to deal with the battery drain issue, I'd get the XL50 instead. Which I still really like and just bought another.
Take a look at the 90% duty cycle runtime test here:I just saw the XL200 dims after exactly 12 minutes for all battery types, leading me to think it's a timer meaning you could get more than 12 minutes at max as long as you turn it off and back on.
The standby current is 33.1 µA, but you can also just unscrew the tail cap enough so that it doesn't make contact anymore.However I read about standby current draw, how bad is it? I tend to charge my flashlight maybe 2-4 times per year as I rarely use them, would I be able to go so long between charges with the XL200?
http://www.led-resource.com/2011/06/maglite-xl200-led-flashlight-review/
Simply 1/4 twist the tail cap. This should prevent discharge.Does anybody know how to fix this high rate self discharge that affects XL200 flashlights? I own two of them and both are affected by this problem... If you leave batteries inside for 2 weeks and a halt, then when you use the Maglite, the batteries will be at a low charge
Point!
"Interesting"
Really? That's how you would describe it? :shakehead
You sure "pathetic" or "terrible" would not be more accurate?
