It will slowly discharge the batteries over 6-12 months.
Ah, OK, that wouldn't be a problem. Thanks. I'll probably go with the XL50 then.
Hey Robin24k, I asked you a question about the XL series lights over on the thread that I started on the XL50.
You never answered, so maybe you didn't see my question over on that thread.
You mentioned several times about removing the battery carrier from the XL lights for long term storage to avoid draining the cells.
I asked if you had tried unscrewing the tail cap about one turn instead of removing the battery carrier?
As you unscrew the tailcap at some point the light will stop responding to button clicks. Back the tailcap out a bit more, just to be sure. At that point the circuit is broken and there should be no standby current flowing to drain the cells.
I think this is a more convenient way to store the light long term. When you need to use the light you just tighten down the tailcap.
Your method involves finding the battery carrier, removing the tailcap, inserting the carrier into the light, then tightening down the tailcap.
The tailcap lockout method is commonly used when storing away lights that have standby currents.
Is there something peculiar to the XL series that I'm missing that makes the tailcap lockout method undesirable?
