McE2S TwoStage Switch: HA-Nat & BK - FS
Status
Not open for further replies.
Phaserburn
Connecticut, USA
Re: McE2S TurnKey tail switches: build to suit
BTW, I don't know if this has been mentioned before. If you're running an L4 with this 2-stage switch and a Pila cell - you didn't have a moon mode before; the Pila would just cut out after draining. Well, you do now! Move the switch back to low and voila; moon mode.
McGizmo
Maui
Phaserburn,
I just did a couple run tests last night on one of Wayne's experimental drivers and in one case the I used a Pila.The graph was a straight line horizontal and then straight vertical when the Pila shut off. I use a single stage clickie for these tests so I can initiate the lightand logging at the same instant. The lack of any moon mode or drop in output was rather disconcerting, to say the least! If I understand you correctly, are you saying that had I been using a two stage, I could have shifted into low and had some output?
Phaserburn
Connecticut, USA
McG, that's correct. My L4/Pila168/2stage produced output on low after falling out of regulation. I didn't think anything of it until reading a different post today that made me remember. Someone else should try it and confirm. I may try tonight if I can.
ubermensch
Iowa City, Iowa
Phaserburn, what resistor value do you use in your pila/L4 setup, and how bright is it (in comparison to an Arc or Dorcy AAA)? I just can't decide what to choose. Also, it might be due to Vf differences, but when my pila/L4 is about to go out of regulation, it gives warning signs--it gets dimmer and produces less heat, but I also get moon mode after it drops out. /ubbthreads/images/graemlins/icon3.gif
Phaserburn
Connecticut, USA
I'm using a 10ohm. It is much brighter, more on a par with an X5T or Nightcutter. Color and beamshape are different than these 5mm lights, but it's a good approx.
BigGuy
Columbus, GA
Just sent e-mail order for:
McE2S Aleph tailcap in HA-Natural with a 30 Ohm resistor
sbebenelli
Iowa
Just sent email for order....
McE2S tailcap in HA-Nat.
What I need to know is what Ohm resisiter I need. I'll be using it on L4 and I want 20-25 Lumens on low.
McGizmo
Maui
For 20-25 lumens on low, you need a L2! /ubbthreads/images/graemlins/tongue.gif
sbebenelli
Iowa
Email sent...
McE2S tailcap in HA-Nat 15 ohm
Mr_Dead
E-mail order for one McE2S HA NAT 30ohm + nickel tab sent.
Many thanks.
Mr_Dead
... and PayPal sent.
Thanks.
Mr_Dead
... and received, everything arrived fine.
Thanks again.
fabian
email on McE2S TwoStage Switch: HA-Nat 22 ohm for L4
thanx
g..
McGizmo
Maui
Hi StanTeate,
I just changed the subject back (you threw me there!) I also responded to your E-mail that I have never made a trim cap with H3 vials as there is no room for them. I outlined your options including a refund in the response. Thanks.
- Don
StanTeate
Colorado
I should have inquired about all the options before ordering. My bad. Reply posted to email. Thanks.
McGizmo
Maui
Hi guys,
This thread is in need of closing and sticking in the attic! Continuation of it can be found HERE.
Status
