scout24
Flared tail? Bear-trap pocketclip? See my avatar... The best there is.
Heh. I disarmed my bear traps so I could use my lights without destroying my pants, but the lights sit so deep in my pockets they still never fall out. That's the best part about the McGizmo(-style) clip, in my opinion, and it's something you can't notice until you use one: the light stays almost entirely in your pocket where it's safe and out-of-the-way.
Thanks, Don. I don't remember ever seeing that suggestion before.Use multiple shims of some sort that are the same thickness so that as you add to the thickness you have a feel for how much you are lifting the clip off the light body. At some point you will lift the clip far enough to induce some permanent deformation ...
Perhaps Don will comment on that.The last thing I need is to break off the screws in the screw holes.
Bending the clip doesn't impose a shear vector force but rather it acts as a tensile strength pull. Tensile strength (at yield) of Ti-6-5 in the annealed condition is 128 ksi (880 MPa). A 4-40 screw has a minor diameter of .081" (2.06mm) so the area is .005 square inches. That means the screw will yield (pull apart) when stretched with 640# of pressure.related to the shear forces involved with using the screws as anchor points while bending the clip past its elastic limit.
If you want to loosen the clamping force on the clip you can do it with the clip in place. Use multiple shims of some sort that are the same thickness so that as you add to the thickness you have a feel for how much you are lifting the clip off the light body. At some point you will lift the clip far enough to induce some permanent deformation (loosening of the grip force). I would think some plastic sheet stock like credit card thickness would work. If you need to increase the clip's clamping force then you do need to remove it from the light.
I never realized how great the ergonomics are on the Haiku/Sundrop/PD-S until working on a similar sized titanium light (SWM V10R). The V10R felt terrible in my hand & that caused me to analyze the McG design. My conclusion is:
Tail shroud design that flares out slightly. This makes extraction from a pocket easy, even with a super tight pocket clip. It also gives the gripping hand a "back stop" (for lack of a better term).
Reduced body tube diameter between head & tail. Lights that don't have this are much more difficult (for me) to grip.
Design of grooves. The spacing & height of the grooves is ideal for a good grip without being knurled or roughened.
Taking all that into account I McGizmo-ized the V10R by turning away half the grooves:
The difference in feel is night & day. Most of us take for granted the superb ergonomics of Don's lights - I certainly did. There's no doubt in my mind that the Haiku/Sundrop/PD-S has the best feel of any light on the market.
Thank you Don for a superb series of lights.
That's exactly what you seeam I seeing it right? u have orings in the spaces in your haiku head? can I please get their sizes and type
You are basically lifting the clip away from the flashlight body and at some point you will lift it past its ability to return to its normal state. It will return but with less force against the body; that is to say looser clamping force. By doing this incrementally you are more in control and less likely to bend it too far. I don't know if I am being clear on this or not.So, just keep adding shims under the clip edge until it bends outward a bit? That almost seems too simple to work. I guess it's the same as bending it by hand except a lot less likely to snap the clip as the pressure is added more gently.
Welcome aboard SAKplumber. Nice images on your Flickr site: http://www.flickr.com/photos/71467108@N08/... And I thought I was gonna spend money BEFORE! Ha...
LOLI disarmed the traps on my Haiku and Mule today ...
HI McGizmo! I was over at EDCF and Okie Chick shared a pic and mentioned something about you and some meet a bunch of you had. I kust say, I had no idea you made such nice looking stuff. I was going to ask where one could see a selection, but just noticed a link in someones signature line.
It's good to hear so many fans reviews.
