wundergussy
- Joined
- May 22, 2013
- Messages
- 57
I meant trade a full Hi-CRI head for the full XML Head. They'd both work on a standard 1x123 pak, right? I don't want to mess with my Haiku in any way.
seafood restaurant in Malaysia, pics taken with iphone and Mule 119v as an extra lighting
What is the typical subject matter for your daughter? What is the distance from her to the subject? How large is the typical subject? If the subjects are mostly people, might want to consider the Sundrop instead. For product/food photos, the Mule is better. I would think that in most cases, the AA hi cri (Mule or Sundrop) would be plenty.I am in the process of looking for a mule for my daughter for her photography and was wondering if the AA Mule would be sufficient, or should I go with the 3V 1x123 version? The AA certainly gives more flexibility in terms of batteries.
No matter what, be sure to get the clip with 1/4"-20 tapped hole. This is what really makes the McGizmo lights uniquely qualified for photo work. I also highly recommend the McGizmo tether with 1/4"-20 swivel. That makes it easy to attach the light to my wrist and freely use it at taking photos without a worry about losing the light. The clip also makes it easy to use tripod heads and hundreds of other photo mounting accessories.
Another attachment you might want to look into for your daughter are some filters for the light. The heads of the McGizmo models, except for the Makai of course, are the same 26 mm diameter. Kodak and other companies made (1-1/32") 26mm slip on filter holders for Kodak series V (5) filters. The filters are all over Ebay for cheap. The slip-on adaptors come in all sorts of variations but any series V slip-on 26mm should do the job. The green, red, orange, yellow filters are cheap and easy to find. Adds an interesting element to photography.
Hi DTF,
Which high CRI emitter is your Sundrop equipped with? Is it the Nichia 119 or the older 083?
I believe that. Personally I have no experience with the 083 emitter but I if I am not wrong it is more neutral in tint than the 119?Mine is an 083. That's just what I ended up with. I'm sure the 119 would do much the same job.
The correct answer to which model to get, Mule or Sundrop? is to get both, of course.
Which model is correct is as much a creative decision as a technical one. I've used both and have come to rely on the Sundrop for people pictures. The reason for this that it has better reach and a nicely defined circle of light. I use that reach and the circle to frame the subject. Here's a good example of this technique. The Mule in the same situation would have produced a much different shot. I think this is a particularly good, colorful, example of the hi-cri nature of the light produced by the Sundrop.
D4A_2507.jpg by Dean Fletcher - Photographer - Portland, on Flickr
Hi, DTF, thanks for sharing, nice pic.
How far was between Sundrop and the girl when you take the picture?
Lens was a 24mm, so it wasn't very far away... maybe 4-5 ft.
