McGizmo Sun Drop XR-U Problem
LATimber
I have a SunDrop XR-U that is acting strangely. When I turned it on this evening, it cycled through all 3 levels and then stopped on low. I thought that it might be an indication of a low battery, so I put in a fresh CR123. Whe I turned it on it came on low and gradually built up to high. It is not repeatable at this time. This is the first time I have had to change he battery, so I do not know if this is a normal occurrence or if there is a problem with the light.Any insight is appreciated.
nbp
Wisconsin
Did you cycle quickly through all the modes several times, as in change the modes a dozen times or so in rapid succession, by any chance?
yoyoman
Switzerland/Scarsdale
After the light came on low and ramped up to high, did it change modes as expected? Multiple mode changes, as mentioned by nbp, triggers a calibration routine.
McGizmo
Maui
What you describe is definitely calibration mode which is entered by a series of fast off-on cycles strung together. If you did not input this series then I don't know what is going on unless the battery when it got depleted somehow cycled through such a series on its own. I just got an e-mail from another user who has described possibly the same behavior and related to a depleted battery. His e-mail came today and I read your report today as well. At this point I don't know what is going on as this is all brand new to me. I have been using the same version of 3S converter now for quite some time so my guess is that there may be a new battery that has entered the realm but it's a guess with little substance and no support at this point.
LATimber
It has not repeated the symptom at all today, I will write it off as the ghost in the machine... thanks to everyone for all of your input.
