So far the bodies (bezels) except 86mm convex lenses. That's if I make ring holders thin to hold them. It could accept from 78-85mm aspherics as well with a flange ring lens design. The focal length is long, can get 60-62mm roughly depending on height of heatsink. The body provides this by its length inside the head available. I have the hosts, but the host needs some better machining, and some custom parts for a design I could run some batches of. I am going to try to turn the sinks on my lathe, but the light has two design models I have nearly finalized. A thrower in one design, very low beam angle. Then, a very large internal copper sink design, higher wattage, and 12x XM-L2 as a variant in another form, with different heatsink internally, but same exterior design. One just throws a massive amount of lux out, one is capable of very high Kcd. It is not close to being final for production, though, so I don't want to pretend these are weeks away from appearing. The body is final, about it (like I said, design is too, just needs to be completed). The circuit boards are covered, the German drivers deliver over 100W each, so I'm good there on power delivery. To produce the huge wattage model, I need a bigger lathe chuck, I simply cannot turn the copper myself on my current lathe. So I have to have the heatsinks for that version made by a CNC shop/owner or someone with a bigger lathe than me. The thrower is still in a technical phase with the collar system, one that further amplifies light, more so than a bare wavien collar, focuses the light to a smaller image. The collar needs to be modified, and another type of optic needs to be centered and glued into the light collar to make it durable in a drop or bash to retain full alignment. There are some production steps, basically, that I still need to find the right machinist/shop for. But, I have the right host for the needs, and I have the right heatsink designs figured out. I just need to get batches of them machined for me to get the price down, and that will take some searching. They are solid copper, the driver attachment that is, and the internal LED sink. I'm using one primary light design to cover two completely different throwing needs. The aspheric is a tougher project to pull together, so it's been a lot of testing, and throwing ideas out, bringing new ones in, getting closer to a good design for real use. It's a long process.
I cannot give any unofficial numbers. I did some initial calculations, but it could vary so much depending on the final lens mfgr design, that I feel it would be false advertising right now. Kcd may fall shorter than expected, and then it would be a let down and require design change. The tests are showing that the light is going to reach some really high values, that is based on its sheer size. This may not be appealing to some, but the goal is runtime, not just a blast to dead batts. So, I chose 3x 32650 cells as the handle size. The Feilong cells pack a lot of energy in 3S, 12.6V configuration. The good thing is, the drivers do have a soft start of amperage, so immediate load is not placed on the switch click (also a beefy switch, in its own right).
