milkyspit
Scott, how much of a lumen upgrade do you think is possible by simply replacing the emitter in the new short L1 with an SSC P4. Would a P4 work with that optic, or would you recommend a reflector?
Thanks,
Josh
Josh, a reflector would most definitely offer a smoother beam, plus allow for some other options in terms of the actual beam geometry... one example might be an intense hotspot combined with medium-radius but very intense, even sidespill... another might be a very soft hotspot coupled with super smooth area flood.
As far as brightness, right now the Seoul SSCP4 parts won't be all that much brighter... they'll probably be a little brighter though. When Seoul releases the successor to the SSCP4, which I've heard might happen anytime toward the end of this year, or perhaps January or February of next year, we'll be in a great position to deliver the above advantages of a reflectored light AND bump up the brightness quite a bit more, too. :naughty:
Hope this helps.
