My ongoing Niteye Eye10 TiC Emitter Swap
somnambulated
I've had an Eye10 TiC that's seen heavy edc since release. Recently, I decided an updated emitter was worth the risk, using the guide posted in this very forum.
Nichia 319AT:
The LED star had to be filed down significantly to fit. I did it with a Leatherman Squirt file.
Having frayed the wires too short soldering and desoldering to find a short, I eventually had to replace the leads on the driver.
I stacked a nylon spacer with a translucent adapter from Mountain Electronics and a GITD o-ring
Unfortunately, I can't find an assortment of GITD o-rings online, and the Flashaholic supplier I loved is now out of business.
Here's a poor beam shot:
Unfortunately, that was the last I took before accidentally de-doming the LED & phosphor while cleaning off some residual Arctic Silver.
The 319AT 70+ CRI was yellower than expected, but beat the violet blue without phosphor.
New LEDs on the way. I'll either be reflowing on the cut-down star, or starting from scratch!
somnambulated
Thanks for moving!
I reflowed a Nichia 219c 80 CRI 5000k to the board. Board's a bit chewed up and toasted from the lighter I used, but it's better than re-filing one!
Anything to avoid re-soldering leads the inside of a dual-layer board that doesn't pull apart.
Cut down a 3M heat resistant insulating gasket to keep the reflector from shorting on the solder.
GITD o-ring effect isn't bad.
jon_slider
congrats on your progress
did the 219c work properly?
any change to the way the ring responds?
do you have a light meter?
have you seen this: (V11r modded w 219c 3000k)
notice in the video that the numbers keep changing without touching the light.
notice that the brightness drifts a large percentage
notice that the brightness changes by reorienting which way the light is facing, without moving the control ring
got any of these symptoms after the LED swap?
note this may not be visible to the naked eye
theatrus
Without a proper integrating sphere, the difference is most likely measurement error from this meter and integrating method.
I'd expect output to shift over time due to thermals until it reaches a steady state of temperature, assuming input voltage remains the same.
