MrNaz
I'm getting to the exciting end of making a light myself. Here are some pics of the build so far:
http://www.mrnaz.com/?s=publish-gallery&album=57
Those optics are the DX ones. I was going to use LC1 optics from cutter, but I found that the DX ones put out a far more useful beam, were easier to install and had a far more uniform and pleasing tint. I've tested it with 2x CR123a batteries, at about 1A. I plan on pushing 2.5A or so through it, using an MCE/P7 driver from the 3P2S array of 18650 batteries into the R2 LEDs which are wired up in 2P2S formation. This arrangement should give a burn time of around 3 hours on high. I will likely have a second position pushing 350mA to the LEDs. This will still yeild a bright light, and should run for over 20 hours.
Does anyone have any feedback on this so far? Especially the size and looks. The handle of the torch, the narrowest part, is 46mm in diameter, which is a little large for my small hands, but not too much. The bezel is 62mm in diameter. What do people think of this for size and shape for a primary light?
