[ QUOTE ]
Smaug said:
BF Hammer, Phaserburn, Anyone? - What is the difference between a Epieon and an everLED? Are they about the same, just made by different companies?
[/ QUOTE ]
I'll add some extra info to Phaserburn's reply - the Epieon and EverLED are indeed both 1W Luxeons, but the method of powering them is different, and the emitter shape is different. Epieon is a high dome and and will output a beam (although very short) without a reflector, EverLED is a side-emitter and absolutly needs a reflector to work. Epieon uses a current-limiting resistor to drive it, you have to have a specific light in mind when ordering because you need to match it with the number of cells in the light. EverLED has a regulator circuit and can run in different configurations. They cost about the same, and neither is really any better overall than the other, it just depends on what light you want to put it in and how you want to use it. I bought my Epieon just before the annoucement of the EverLED and likely would have chosen the EverLED over Epieon if they were both available at the time. Still, I'm happy with my choice and don't regret it. I know, if I am to become a true flashaholic I should buy both! But not today.
