rockz4532
maybe some oil on the reflector?
alright...got a picture uploaded before bed....
Bet there's a break between the phosphor and the emitter, or something's pulled open making a wedge/prism gap.
Wow, there is always someone who knows the answer to even the most random questions. Excellent post MrGman!The multiple rainbow color patterns is the repeating refringent pattern of light through plastic that is under stress. There is actually equipment that is used that can tell you how much microstrain exists from going through the rainbow pattern. If the lens or "window" in front is glass it can't be that. It is most likely that the heat has stretched and then shrunk the plastic lens bead sitting on the die itself. And only because it was well bonded and has not peeled off do we now see the stress pattern in that plastic lens sitting on the LED die. If it peels off and relieves the stress the rainbow pattern would go away. It may have partially detached from the die and the air gap is causing the reduction in total output.
I have actually worked with equipment to do this intentionally to look at the stress pattern in plastic models of mechanical equipment to study where the stress is.
to prove the point you can take any piece of clear plastic and look at it through polarized sunglasses and bend it and flex it in a light source and watch the diffraction of light come and go with the bending stress. Polycarbonates are great for this, but its not the only plastic will do this. I have done this many times. In fact I have inspected plastic samples of material that was going to be used for lenses before and after thermal cycling to see if they would exhibit this phenomenon and take pictures of them through a polarizer to see what happens.
The reflector is acting as the polarizer of sorts but should not be causing this effect directly.
The plastic bead that is the lens over the die got too hot sitting some where, probably the van as you said.
G
> a wedge/prism
elaborating slightly -- if there's a lens (bump of clear whatsit) that was glued over the LED with something like the clear glue typically used to assemble lenses, and that glue softened while you were baking the light on the dashboard, it could've slipped a bit leaving a prism-shaped space still filled with the glue.
Got a way to do an extreme closeup of the thing? You might want to patent it ....
