For the sake of not starting a new thread, I'll just ask in this thread as it is about heat management. How long can I run my MC-E Alpha on high without causing a problem? Has anyone run it for an extended period of time? Does the light step down a level if it overheats or anything?
I think I can take this one
I also encourage people to speak from their own experience. As far as I understand, the driver has some sort of passive thermal protection and will reduce the current at some point. This was told to me by someone who should know, but I really have no idea what the mechanism is or how it works. Feel free to address this
I've run one so hot it melted the heat shrink on the positive end of the battery. This was a 30 minute torture test with the light sitting on a table. You should never (ever) let the light get this hot. At this point, extended contact with the head would certainly burn you. Again, I consider this situation abusive and should not be allowed under normal circumstances.
My rule of thumb is, if you can't hold it by the head, then it's too hot. The Alpha should
never be run on high and left unattended like I did in the example above. The amount of time that it can run "depends" on a number of factors: ambient temperature, if you are holding it or not, level of charge, etc. Some people opt to move their hand away from the head as it gets hot. This is the wrong approach; keep in contact with as much of the head as possible and your hand will actually cool the light. Too hot to hold? Like I said, shift to medium, turn it off, or throw it in a bucket of water. If you are outside in sub zero temps...you can probably run it until the battery runs out. Same if you happen to be under water. The light will run hotter on a fresh battery because it will draw more current. The light is regulated, but only to the point where the battery Vf (under load) exceeds the LED Vf. After that the current will fall off accordingly. Less current = less heat.
If you want an actual number, I'd say ten minutes on high, but you should really let your hand tell you what is too hot or not.
