I know it is a poor image but here is a frame containing electronics from the back of the circuit board.
[/url][/IMG]
Some quick thoughts:
- Hope it works as "advertised", but I am skeptical, at least from a practical standpoint
- Quoting 133 lumens/watt AND saying it has been tested at independent labs, but not putting a copy of that test report in the Kickstarter makes me a bit suspect. I will believe it a lot more if signed by a recognized lab. Having a display show 1600 lumens is just about meaningless unless the test was run by someone who knows how to calibrate and operate the equipment. That is a generic spectroradiometer. It would need to be calibrated with a standard source in the integrating sphere. Was it done?
- 4000K may sound great, and I do like 4000K, but that is likely the lowest color temp they were able to get high lumens/watt LEDs at. Of course, those high lumens/watt bulbs have poor CRI. Most of the ones at 4000K with high lumens/watt have poor CRI, 70 or less. That is a fine light for outdoor lighting (what it was designed for), but not so great inside. Think those nasty CFLs that many people do not like.
- Though they claim it runs cool, we are still talking say 8 watts dissipated on a fairly small surface area. I would expect that to be warm, not hot, but not cool either. Interested to know what the coating is. You can increase emissivity with coatings to a point but that mainly helps when the surface is warmer. You still need area.
- Given they say the LEDs are Korean, and they look like Seoul Semi .... what do you think? I am not sure Seoul even has anything that is this efficiency? Remember that is 133 lumens/watt at temp, with AC losses. They could have a real hard time with color consistency bulb to bulb. This is one of the limitations on ultra efficient LED products today. Sure you can buy the brightest bin, but good luck getting it reliably at the same color co-ordinates ... even when willing to pay more.
- The 12W version looks like the LEDs are behind the board. How are they transferring heat to the board?
- The 10W version looks like the LEDs are sitting on top of the board? I wonder if that will pass safety certification? There is no discussion of that and no isolation in the circuit. Even the 12W version could be iffy in that measure.
- The low PF means no EnergyStar. There are so many off the shelf driver designs that dim, this should be an easy upgrade and some are pushing high 80s - 90% in this power range. Would be nice to see an upgrade.
- The assembly with the folding boards is pretty cool. It will need to be sturdy to ensure it can't easily fall apart if someone screws it in/out while turned on. That goes back to the safety/approval thing. Even if it was spray encapsulated, I still think it is interestingly viable but that would kill the heat dissipation.
- Multiple point sources, but not a lot of them, tend to create unfavourable shadows at close distances. Likely not an issue for the 12W, but could be for the 10.
- The design occured in North America, but the testing that was shown was at 215V ... so likely in a lab in Asia? ...
I am tempted to get one just to try it out, but have asked some questions on the Kickstarter first.
Semiman
