LightScene
- Joined
- Sep 12, 2003
- Messages
- 939
The Jetbeam Jet III M (Military) uses one 18650. It is good sized. It has 2 levels - 1) full - head tight, 2) your choice - head loosened. The rear clicky switch is 'tactical', meaning it turns on as soon as you press it and stays on if you click it. For your purposes, the Warm version with OP reflector should be perfect. I just tried it at my desk and the full brightness is not startling to the eyes. This flashlight costs about $85 and is built very strong. The bezel is flat stainless, perfect for standing on. The tailcap is also stainless. The front lens is shock protected. At a distance of 6", the hot-spot has a diameter of 1". There is no dark spot in the middle at any distance.
When you asked about over-discharge, I think you meant over-charge. As a precaution, you could put the charger on a timer, just in case it malfunctions. I don't worry about it myself, but some people in this forum are very paranoid on this issue. You could also create a charging station that is fire proof - like the inside of metal trash can, etc.
