Re: Need advice on emergency power generator purch
Any generator OTHER than a honda eu series is gonna get might old on the noise problem after a day or so.
I have lived for days with out power and the honda eu2000 is the only way to go. It's portable so you can use it for other purposes. I have had no problem with fueling while running. The exhaust can be used to dry clothes and heat jugs of water.
I have also had an eu1000. It will run some microwaves and some fridges, but not all. For a few dollars more, get the 2000.
I would also get the 12v dc charge cord for the honda also. That way you can use it to recharge you car battery/lawn mower battery/etc that you are using indoors for light.
I also agree with someone else's above post. Heating with electric heat is really inefficient. This also goes for cooking. A multi fuel (gas, diesel, white gas, kerosene) camping stove can be had for $50 (cheap) or $100 (excellent). These guys will cook for a week on a single gallon of auto gas/white gas.
It has been stated somewhere else that you're really only looking at running the fridge and a few lights. Most of the time will be spend in daylight, or sleeping at night.
I'd be sure to keep an extra spark plug on hand. There's no fixing these things, and your neighbor is not likely to have one to loan you.
But back to the original post for a minute...... propane and natural gas have low energy densities compared to gasoline. If you store it yourself, it's gonna take a LOT of this stuff to keep you in power. If you go with a gas engine you could simply siphon/pump the gas from the tank on ONE of your cars and you instantly have enough gas to run for a week or more. I'd keep a small hand operated pump around. This way you can suck gas out of cars/lawn mowers (mine holds 11 gallons!)/the neighbor's car (at night)/etc.
Candles keep forever and provide a long lasting source of light. Don't burn your house down though.
My current kit/setup includes:
honda eu2000
various lights
candles
oil for generator
hand pump for gasoline
200w inverter (so we can run a radio w/o running the generator)
msr cook stove with 1 gal or so of white gas
candles
water purification pump/filter assembly
14 gallons gas in cans
11 gallons in lawn mower
24 gallons in truck
14 gallons in car
That's 63 gallons of fuel. That'll run the honda 2000 for 15+ days straight at full load. If you don't have some help by then..... it's time to go hunting and try and kill something to eat.
