Need recommendations for a flashlight for security work
Habu
I need a flashlight for work, but am not having any luck finding what I'm looking for. The flashlight is going to get activated a few hundred times a shift, for a few seconds each time (a series of security checks at 10 minute intervals). It needs to put out no more than ~50 lumens, take AA batteries, and with a momentary switch in the endcap. A red or blue filter would be nice, but not critical. Per company rules, it can't have crenelations, skull-crusher, etc, because that would make it "tactical".
I've no objections to a variable power flashlight, but it has to be one that can retains the desired setting. I found one that was almost ideal, except you had to cycle through the entire power range, every time.
Thanks!
==================Flashlight Recommendation Checklist================
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use "Primary"/Disposable Alkaline batteries based on AA sized cells.
____I need something in the 40-50 lumen range.
____Danged if I know--I need to cover about a 1-2' area at 10-15'.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____I'm not sure how this applies, the light will rarely be on for more than a few seconds.
(With the lights I've used so far, the switch has been the failure point.)
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a tail mounted switch (found on the majority of today's high end lights).
____A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
____I don't care.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
16) Storage conditions
____Other: will be carried in a pocket on on belt, with frequent daily use.
____Red filter would be nice at times, but not critical
____NO Crenulatations at either end.
