Need Some Ideas For next 2C m@g mod
Justintoxicated
El Cajon, CA
Well, I'm very happy with my 3C mag mod. This light is great, although I want to make something a little bit smaller next time.
I found some nice 2C mags at home depot and felt this would be a great size.
I need everyones feedback on the following setups.
Lux III is a SX1J...Using Hotlips HS from Hotbeam.
1) Will 3 123's fit in a 2C mag? How can I acomplish this (Sleve etc?)
2) would I be better off Boosting the power from 2C's to 750ma or limiting the power from 2 or 3 123's to 1 amp? etc.
3)From the above, what would be the best choice (batteries and converter combo)(best runtime at highest brightness possible)? What would be the least complicated?
thanks,
JI
MR Bulk
Hawaii
Cut waaaay short, put 9V in sideways, run a 5W HD Luxeon - for an instant, anyways...
IsaacHayes
Missouri
See Orions thread about 750ma boost using 2 cells. It can be done as people have done it. I'd use a BB600-750 and pot it in the base of the hotlips. 123's would be silly in such a large light to power only a luxIII. Plus they are harder to come across...
I was going to suggest putting a red or red/orange in there and DD'ing off of 2 C's for a long throw red mod. But I see you have a luxiii there...
Justintoxicated
El Cajon, CA
hey guy's I really do not understand either of these 2 mods lol...I have no clue where to get Li-ion or a charger and all that stuff, it doe snto sound very practicle for me...Id rather use disposable 123's or C's or NIMH...But I need to figure out if 3 123's can fit without ordering them because I have nothing else to use them for. As far as cutting the light I don't have a tap or anything like that to add new threads. Just want something a little smaller than my 3C...With decent runtime..
I already have a hotlips and SX1J bin Lux III I want to use.
Gadget_Guru
Brantingham, NY
For Lithium-Ion cells and chargers, eBay is the place to look. Lots of surplus and used batts and chargers for obsolete cell phones there.
I just got a great deal on eBay, which included:
Two batteries for the Qualcomm 820. Each has two 18650 Li-Ion cells inside in series, and a nice, small protection circuit. Still running them through my Triton charger to measure actual capacity, but I think they're around 1350mAh.
Two chargers- one for a cigarette lighter in a car, the other for home use. The best part? Both batteries and both chargers were a total of one cent...
Darron R. Birgenheier
Brantingham, NY
illumiGeek
Kapolei, Hawaii
3x123 fits very nicely in a 2C Mag. Use some PVC or PEX pipe for a diameter adapter (and wrap it in Duct tape to get the pipe to fit without rattling). I used 3/4" x 7/8" Hot/Cold Pex pipe, and it's a perfect fit for 123 cells.
3x123 is slightly longer than 2xC so I trimmed a little off the rear spring so it wouldn't be too tight (I thought it was too tight even with the stock C cells).
I'm running mine with a GH24 lamp (6V/1.7A) and at this over-drive level I'm probably getting around 15 watts output. Bright as hell, and very white for an incandescent light. Battery life is not too great, but it's FUN while it lasts.
Take a look at this thread for more info on 2C/3x123 incan mods...
If I was going to do a 2C/3x123 LED version, I would probably make a battery adapter that would run them in parallel and use a boost circuit.
Another option would be to get some 4/5 Sub-C cells and run them DD. If I remember right, 3 of those should be the same length as 2xC and should drive a Lux 3W very bright.
Anyway... just a few suggestions.
Aloha, iG
Justintoxicated
El Cajon, CA
Gadget, I have some old cell phone battery packs if I cut those apart there are Li-Ion cells inside?
illimiGeek, im very interested in running them in parallel for the Lux III.
What is the advantage in running them in parallel with a boost circuit vs running them in series with a limiting circuit? I thought the limiting circuits were more efficient?
Finaly if I choose 3x123 would I be better off using a Lux V? I hear they do not last as long as the Lux III
Thanks for the ideas.
JI
Gadget_Guru
Brantingham, NY
Justintoxicated, you'll need to see if the label on the cell phone's pack tells you what chemistry it uses. It should say one of these:
NiCd (Nickel Cadmium)
NiMH (Nickel Metal Hydride)
Li-Ion (Lithium Ion)
Li-Po (Lithium Polymer)
The last two chemistries have only been in wide use for a few years in cell phones, so there's no guarantee an older phone would have them.
If the phone pack uses one of the last two types, it will also contain a protection circuit to prevent over and under voltage, which can damage a lithium cell (sometimes with rather catastrophic results).
If you're VERY aware of the characteristics of Li-Ion cells, you can charge and run them bare.
Brantingham, NY
Gadget_Guru
Brantingham, NY
illumiGeek , you're right about the 4/5 Sub-C cells. Three of them will fit very well inside a 2C M@g, and will direct drive my TWAK LuxIII at about 1100mA when fully charged. This is with 18-year old cells from an old Makita cordless drill, newer cells should do slightly better.
Brantingham, NY
Gadget_Guru
Brantingham, NY
Another thought- three regular Sub-C cells will fit in the 2C M@g with a minor mod: the tailcap's inside diameter needs to be enlarged, and the spring removed and a shorter one substituted inside the tailcap.
Regular Sub-C cells are available in up to 3300mAH capacity, while 4/5 Sub-C cells are much harder to find, and have far less capacity.
Brantingham, NY
Justintoxicated
El Cajon, CA
what about running it on 123's? I was thinking that I would like to run it on 123's or just 2C and a booster circuit if possible. You mean I can remove the spring and fit a 3rd cell in a 2C?
admedeus
Bowling Green, KY
You can get 3 C's in a 2D body if you cut the spring. The 2D body is slightly larger, but then you could DD the LUXIII the the Hotlips. OR you could run 3X123 in the 2C and DD a 5W, if you could find a nice one. I have one of each of these configurations and pleased with both.
David
Justintoxicated
El Cajon, CA
the 2D is too big for my tasts, I'd rather use a 3C than a 2D, Bu tI already have a modded 3C mag...
Im thinking about using 2C and a booster circuit or 3 123 and something like a downboy. Im not sure how much better one would be over the other. I'd prefer to use C batteries but if the 123 would with a down-converter would be way better Ill go with that.
Again what is the advantage of using 3 123's in parallel with a boost circuit??
IsaacHayes
Missouri
You could wire up 3 123's in parallel but that could be hard and you'd have to do that each time you change battieres. You'd get 3x the runtime of 1 123.
illumiGeek
Kapolei, Hawaii
The reason I wouldn't go with a Downboy is that the Lux slug has to be insulated from the heatsink (electrically) and that will affect the thermal efficiency. The brighness of a Lux (not to mention its lifespan) if affected by its temperature, and I know of no way to electrically insulate the slug without a significant impact on the thermal coupling.
For a 1W that is not driven at very high currents it's probably not significant, but when dealing with 3W driven hard (1A or more) the thermal impact would be greater. With better cooling you should be able to get higher, and more maintainable brighteness.
Then again, I may be completely wrong about this. I have not verified it with experimentation. But the thermal data on Luxeons shows a negative relationship between temperature and brighness (& lifespan).
In a 2C host it should not be too difficult to rig a parallel adapter for 3x123 cells. There is plenty of room around the batteries in both length and width.
As for boost circuits being less efficient than buck circuits, I don't know about that? Is that true?
Gadget_Guru
Brantingham, NY
I've not been able to measure any continuity between the LIII's slug and either lead. I just use Arctic Silver thermal epoxy to adhere the emitter to the HotLips, or other home-made heatsinks. Works fine...
Darron
Justintoxicated
El Cajon, CA
[ QUOTE ]
[/ QUOTE ]
Actually I jsut plan on using the circuit to regulate voltages. The Lux III itself will be attached to the hotlips Heatsink, and Ill put the circuit behind the hotlips. THere should be plenty of room.
Can someone explain why I would not want to use 3 123's in series with a buck circuit?
illumiGeek
Kapolei, Hawaii
[ QUOTE ]
Darron
[/ QUOTE ]Hmmm... that's interesting. The docs for the Downboy says the slug is ground and must be insulated from the sink (electrical ground).
Gadget_Guru
Brantingham, NY
My DMM goes up to at least a couple megaohms, but can't find continuity, even at this high impedance. I am testing with the emitter epoxied to the heatsink, with one of the DMM's probes on the heatsink, and the other moving between the two LED leads. Perhaps the Arctic Silver thermal epoxy is doing a better job of electrically insulating than the maker claims.
Darron
