Of course a person could get a lot of bang out of going after the reflector coating instead, or other areas...
How so, many are inclined to ask. Well...
http://optoelectronics.perkinelmer.com/content/RelatedLinks/Aero_WP_EF_Optical%20Coating.PDF
Go to Figure 1, and take a look at the various coatings.
Now go here and look at Protected Silver:
http://optics.mellesgriot.com/opguide/oc_5_1.htm
That gain is significant.
Next I'd be looking for serious thermal transfer over the largest surface possible to keep the Luxeon slug as cool as possible.
Then I'd go for a high efficiency converter, to minimize heat generation, and prolong battery life (impact is greater than first imagined, since efficient converter draws even less power out of the battery, so you get less losses in the battery also.)
And I'd be looking at a minimum of 2 sided AR coated borofloat, or one of the perfectly clear glasses like B270 or Eagle 2000 with 2 sided AR coating.
Then if ->I<- didn't need it right away, I'd definitely wait for the release of the Luxeon IV, since the output is higher (greater efficiency), and it also has a much lower thermal resistance. Instead of just a marginal and debate ridden increase of a U bin vs. T bin.
I'd most definitely not be trying to compare WO vs. X1 color bin parts for brightness, while also comparing T vs. U thats nearly a sin in itself. While we are on that subject, photos which show the two lights side by side in the same photograph are more valuable, imho...
Then there is the point of how hard you are driving the Luxeon. The light output curves actually do change within the same bin. If I use 50% the power, of two matched parts that were matched at 700mA, the likelyhood of them being the same brightness at 350mA is *exceedingly* low. At the seminars, LumiLEDs used to basically say, if you are running them a different current level then they were binned at, all bets are off. After measuring quite a number of LEDs, I'd most definitely have to agree wholeheartedly.
Then also keep in mind, they are binned at 25 Celcius junction temperature (Tj). In real life, there is a very high chance the die will be 85-110 degrees Celcius. Why does that matter?
Well, as the die temperature changes, the wavelength (color) of the blue LED inside changes. This affects the phosphor conversion efficiency, which changes the ratio of the blue LED output vs. the "yellow" YAG or YAG:Ce phophor. So, what does that mean to me? Well, it means that the bin is going to change, since it is not ran under the same conditions as it was binned at.
It looks like the Aleph series has outstanding thermal sinking, and I really can't wait to get my hands on the new Aleph III head. The thermal efficiency will improve even further with this nice large head.
Of course, great thermal managment (good heatsinking), is going to go a very long way to providing a person the lowest possible die temperature. The other great thing, is the output of the Luxeon gets more efficient, the cooler you keep it.
So, we run them at a different current, different temperature, very doubtful you'll stay in the same bin...
Even when PWM dimmed, the LEDs shift very significantly, even if you regulate the current pulses very carefully:
Compare the change in output when compared to current dimming:
All that said, in the end, if you need it now, or don't want to wait until someone gets a premium color, intensity, Vf bin Luxeon IV, since there probably won't be a lot of selection to pick from at first (could take months on months), one of these T or U bins would be a great choice.
Personally, if I was that picky, I'd ask the maker of the lights actually measure his batches when built up and finished, and pick out the best, once built, and offer him a Premium price for doing so. Of course, that is a pain for the maker too...
