Fireclaw18
- Joined
- Mar 16, 2011
- Messages
- 2,408
I wonder if a triple 219 would fit? The triple optics seem to fit in there just fine, but replacing the driver could be a pain.
Interesting. I haven't tried that.
The emitter compartment of the pill is maybe 15mm across. a 14mm star fits fine. A 16mm star is a tight fit. Typically available triple star and triple optics are 20mm.
Assuming the interior of the body is at least 20mm wide, this could work. You'd have to completely remove the reflector and possibly the top of the pill with the reflector screw threads. Then make a platform out of cut pieces of aluminum or copper for a 20mm star to sit on. Adjust the height of this platform so the led, star, optic and lens are at the right height when the bezel is screwed down.
The driver would be tricky. The S10 uses a custom electronic switch driver that outputs pretty low current to the LED. To make running triple emitter worthwhile you'd probably want a 3 amp driver powering three emitters in parallel (so 1 amp per emitter). You'd probably have to completely ditch the S10's driver and make or buy a custom-programmed one. I know of one guy who custom programs 17mm Nangj 105c drivers (which can easily be shaved to 15mm), but I'm not sure that driver would fit into the light.
If the interior body of the head is narrower than 20mm then forget making a triple emitter mod. It won't work.
____
After glancing at my S10 I think it might work. Might have to plan this out as a mod to try. Perhaps something along the lines of the following:
1. Olight S10 - chop down top of pill and build heatsink out of copper disks. Replace emitter with 20mm triple star with triple Nichia 219.
2. Replace driver with custom programmed Nangj 105c 2.8 amp driver with shortcuts to min, max, 10% and 2-way ramping.
3. Rebuild inside of pill including switch mount. Possibly replace switch with Radio Shack momentary.
4. Run on IMR 16340.
Or for something more ambitious...
1. Olight S20 - same as above for S10, but also chop body tube in half and remove center section. Glue smaller tube back together.
2. Replace emitter with triple XP-G2. two neutral tint and one cool white tint.
3. Replace driver with custom programmed Nangj 105c with extra 7135 chips attached for 5-6 amps.
4. Switch same as above for S10.
5. Run on IMR 18350.
