Haven't forgotten about you Colin, just been running instead of riding lately so hope these backyard beamshots will give a good representation of the spill. Over the weekend I tweaked the focus slightly by tightening the retaining ring to push the heatsink a little lower, right now the top of the XRE ring is level with the stock Q3 reflector lip for a large hotspot with wide flood. Good news is that the small crescent shaped shadow around the corona isn't visible anymore!
The first light is the HDS B42 from the first set of pics on Max brightness, compared against the P2 bin XRE on FLuPIC burst mode.
If the retainer ring is adjusted to raise the XRE up into reflector, it results in a smaller more intense spot with excellent throw but much reduced sidespill and slight donut surrounding the hotspot. Flood is more useful on a bike, so I simply re-focused back by tightening the retainer. This trick only lasts for so long, after being compressed the foam looses it's ability to spring back so I'll try to find an expansion spring that's the right diameter.
Tranquility Base, I'll take apart to add more thermal grease onto the heatsink and will measure the height for you as well.
Another comparison from the park...
