Hello all,
Seeking some advice on a setup i am attempting to design.
Recently finished construction of a horse shelter/feed shed and require to have internal and external lightning for it.
It measures 8m by 4m (26'*13' approx) and is divided by an internal wall half way to make 2 bays of 13' by 13'.
One half will be used simply as a open access shelter for the horses and requires no more light than to walk by, the other will be a feed storage/mixing station and requires a bit more illumination, within this will also be a workbench. A few flood lights on the outside of the building would be required as well.
My current thinking is a solar panel (mounted on roof) with deep cycle battery. All the lights i plan to have operated by a manual switch and most likely wont be used for any more than 1-2hrs per day.
I been flicking through a few different ideas including LED strip lightning, caravan lights, Outdoor floods lights, individual leds mounted on heatsinks etc. but struggling to find too much relevant information from recent sources. Looking for more information on what people would recommend is the best approach as well as including possible sources and specific sources.
I am a competent tinker and wont shy away from utilizing raw components if it will build a better system for less.
As always the less spent the better, but the light needs to be fairly good as it is primarily for my father who has less than ideal eye sight.
Any ideas and recommendations would be appreciated.
Cheers,
Deelirium.
Cheers,
Deelirium.
