CelticCross74
just pulled the trigger on the ET G25C2 MkII XP-L HI. Will have in a couple days and try to post comparison pics
I have the Armytek Predator Pro v2.5 XP-G2 and the Olight M23. The initial result after step down of the M23 is that it losses out on throw to the Predator; but the difference is tiny in terms of lux on my units. Time tested at 9 minutes for both lights.
Predator v2.5 XP-G2 33,000 Lux
Olight M23 UT Javelot 32,500 Lux
I suspected it would be close, but not this close.
One more thing I forgot to mention, if the timed step down is indeed for protecting the light, wouldn't resetting it continuously to max output as you've described defeat that purpose?
I also wonder whether manufacturers sometimes also use step down, be it timed or temperature controlled, to obscure the fact that their lights don't have the circuitry to maintain max output for extended periods. In other words, instead of coming off as having poor regulation or runtimes on max, thermal protection is used as a distraction or an excuse.
Thanks for the review candle lamp !! . I have a M22 but it seems i'll be getting a M23 as well
Is the M23 production switching to the factory de-domed XP-L HI emitters? Or will they stay custom de-domed by Olight?
That's why I asked. I was hearing some talk that Cree was not happy with Olight de-doming emitters themselves maybe. So I wonder if they will just buy HI emitters and these will be some of the only lights that are actually de-domed by an actual light maker.
Thanks! Nice review.
Hello, any suggestions on how to disassemble this new tail cap design?
You can find the small gaps on both sides of the tailcap. Just insert the tweezers into the gaps and rotate counterclockwise.
Hello again, can you tell me where I can find tweezers long/skinny enough to fit inside the tail cap? I wish I knew how to upload pics to show you how mine came. My rubber switch cover came not sealed and the button sits sideways pressing against the side of the aluminum that allows for tail standing. I sent pics to Olight and they are sending me a new tail cap but if I can fix this one I would like to.
You can buy stainless steel tweezers through online shopping malls. Don't forget to get the straight one. If you fix the tailcap, please post your feedback. I hope you will replace with new tailcap.
M23 comes with a nice nylon belt holster with a velcro strap on the head. The light fits in the holster head-down only. The small extra pocket at both sides give a nice space to carry 2x18650 or 4x(R)CR123A's. The holster has a loop allows to carry it in horizontal position for belt.
