kj2
Voltage isn't mentioned in the S2 manual, but it does stated that it works on 1x 18650 or 2x CR123. Therefore I expect the max voltage is 6V.
Yes, exactly, that would be the correct conclusion. Thanks!Voltage isn't mentioned in the S2 manual, but it does stated that it works on 1x 18650 or 2x CR123. Therefore I expect the max voltage is 6V.
I have an Olight S30 Baton. I liked the S10 so much, I bought the S30. How does the S30 compare to the S2? Is the S2 the S30's replacement? Thanks.
Olight just confirmed that RCR123A and 16340 batts are not supported and should not be used in the light [emoji3] .Voltage isn't mentioned in the S2 manual, but it does stated that it works on 1x 18650 or 2x CR123. Therefore I expect the max voltage is 6V.
The new Olight catalog (2017) lists 2xRCR123A (or 2x16340 for that matter) as one of the supported batts for the Olight S2 [emoji16].I don't think very many lights would support 16340 x 2. Not sure about the RCR123A issue would be. That would be the equivalent of running eneloops in an S2A, which I assume is OK
The moonlight mode is very dim indeed.
Here a photo comparing it with my S15. S15 on the left, S2 on the right.
On a other note. Right before I made that pic, I opened the light to insert a battery, and the black plastic disk that normally surrounds the spring at the head, felt out. This disk is only for protecting the components on the circuit board, but still, it shouldn't fall out.
