[h=2]http://www.batteryjunction.com/olight-s2a-flashlight.html
Olight S2A Baton LED Flashlight[/h][h=3]Powerful EDC Flashlight[/h]Featuring a compact design and a wide range of useful outputs, the Olight S2A Baton LED Flashlight is the perfect EDC flashlight for any user. At just over 5 inches in length and weighing less than 2 ounces, this conveniently-sized light is capable of producing up to 550 Lumens of brilliant white light that can shine as far as 110 meters, all thanks to its sophisticated CREE XM-L2 LED. In addition to its maximum output, the S2A Baton features four dimmer constant brightness outputs ranging from 300 Lumens all the way down to 0.5 Lumens, as well as a specialized Strobe Function, which produces a steady 10 Hz flash that can be used as a signal or to disorient a target. The impressive light is powered by a pair of AA batteries (included), which can last an astounding 100 days on its lowest output! In order to preserve power and prevent overheating, the S2A Baton features an intelligent thermal protection program that automatically dims to 300 Lumens after 3 minutes in Turbo Mode.
[h=3]Durable, Colorful Design[/h]The S2A Baton is designed to be as advantageous as possible for the everyday user, which extends much further than simply being compact. Crafted from sturdy hard-anodized aluminum alloy, this durable light is capable of being submerged under 2 meters of waterand can be dropped from as high as 1 meter without any damage. Wrapped around the body is a skin-safe silicon grip, available in 4 colors (Black, Gray, Yellow, or Fluorescent Blue), that provides a secure, comfortable hold for its user. The S2A's LED is protected by a TIR (Total Internal Refraction) lens made from strong acrylic glass, which helps provide a far-throwing, evenly dispersed beam for a clearer image. The light even features a flat tailcap that allows it to be stood up on a table or other surface for candle lighting when needed. Conveniently sized and tailored to the user's convenience, the Olight S2A Baton LED Flashlight is the perfect light for any every day user!
[h=3]Features:[/h]
[h=3]Specifications:[/h]
[h=3]Features:[/h]
- Durable hard-anodized aluminum body wrapped with skin-safe silicon for strong, comfortable grip
- Acrylic glass TIR (Total Internal Refraction) lens provides far-throwing, even beam
- Thermal protection program automatically lowers brightness to 300 Lumens after 3 minutes in Turbo Mode to prevent overheating
- Specialized Strobe Function can be used as a signal or to disorient a target
- Built-in timer allows light to be automatically turned off after 3 minutes (Short Timer) or 9 minutes (Long Timer)
- Tail stand capability for hands-free candle lighting
- Available in Black, Gray, Yellow, or Fluorescent Blue
- Included Accessories:
- 1 x Removable Stainless Steel Pocket Clip
- 1 x Lanyard
- 2 x 1.5V Lithium Primary Batteries
- LED: CREE XM-L2 LED
- Power Source: 2 x AA Batteries (Alkaline, Ni-MH, or Lithium Primary) (Included)
- IPX Rating: IPX-8 (Waterproof and submersible up to 2 meters)
- Impact Resistance: 1 meter
- Brightness (Using 2 x Lithium Primary AA):
- Turbo - 550→300 Lumens - 3 Min.→4 Hours
- High - 300 Lumens - 4 Hours 10 Min.
- Medium - 50 Lumens - 30 Hours
- Low - 10 Lumens - 120 Hours
- Ultralow - 0.5 Lumens - 100 Days
- Brightness Outputs (Using 2 x Alkaline AA):
- Turbo - 550→300 Lumens - 3 Min.→1 Hour 20 Min.
- High - 300 Lumens - 1 Hour 40 Min.
- Medium - 50 Lumens - 16 Hours
- Low - 10 Lumens - 45 Hours
- Ultralow - 0.5 Lumens - 45 Days
- Peak Beam Distance: 110 meters
- Peak Beam Intensity: 3,000 cd
- Dimensions:
- Length - 5.2" (132 mm)
- Bezel Diameter - 0.91" (23 mm)
- Weight: 1.98 oz. (56 g) (excluding batteries)
