That's right, I never tested the SR50.I have the Olight SR50 and it looks like you never did a test on it.
The CR123As are Titanium Innovations cells, labelled as 1400mAh. But I can tell you from my current battery testing that they continue to perform comparably to all the major made-in-the-USA brands.What were the battery capacities used in your SR51 Runtime and graph tests?
The RCRs are standard black-label AW protected, labelled as 750mAh. I believe most people consider this to be an over-estimate (e.g., the AW 14500s are similarly rated, but typically have >20% more capacity). Hard to find reliable numbers for the RCR capacities.
The 18650s are original button-top AW protected, labelled as 2200mAh. This capacity measurement seems fairly accurate to me, as runtimes to scale up pretty well again newer high-capacity cells (although that depends on specific current levels).
