Thanks for reading!
Both flashlights SR52UT and M2XUT have almost the same head diameter and length of the body.
The SR52 though is much heavier,which is really good for the heat dissipation,but weighs more when carrying,even in a backpack.
SR52UT=534gr. with batteries
M2X UT=267gr. with a battery
The SR52UT requires some time to adjust the position of the switch in the hand,so the M2X may be a better choice,if quick activating is needed.
About the quality of the light,the SR52UT is very clean white(may be too cool white for some people).The M2XUT in the version I have with de-domed XM-L2 is noticeably greenish tint.
The SR52UT has about 200 lumens more output and at least 20kcd more beam intensity. It also has no timed step down.This could be a huge advantage,depending on the way of use.
I really like the M2X,it is one of the best "pocket" throwers. But to be honest,after getting the M3XS UT,I almost don't use the M2X.
The M3XS UT with two 18500 is also a good choice.
