fyrstormer
Banned
The biggest danger to overfilling the crankcase with oil (aside from crankshaft damage? never heard of that before) is that the crankshaft will whip the oil into a foam (like Cool Whip, only not white), which will then fill the crankcase, and get sucked into the vacuum hoses through the crankcase ventilation system which is supposed to just suck burned oil fumes. Filling the vacuum hoses with oil foam can turn one-way valves into no-way valves, which can cause all kinds of secondary problems including but not limited to sensor contamination, sparkplug fouling, and loss of vacuum-assisted power brakes. It sounds extreme and most of it is, but it's still possible. Better to drain the oil and not take any chances.
