A suggestion for the seoul ssc heatsinks is to make them a little shorter/lower, one mm or so. They need quite some unscrewing to get properly focused with the standard mag reflector/kai OP reflector which makes the mag head wobbly. I use an O-ring under the reflector to raise it a bit.
Thanks. I'll lower emitter pedestal 1mm for the next run.
