Is the McClicky the only switch option?
I am also interested to find which LED modules members are proposing to use. I know the SST-90s are high draw but are there tower module versions available?
Is there going to be some kind of markings on this to differentiate this from the serial bodies are you going to be making?
Assuming the module can take it, would it be possible to run 6x CR123 primaries in a 2S3P 6v configuration in an emergency?
It is possible but wouldn't it be better to carry extra set of 18650 for an emergancy?Assuming the module can take it, would it be possible to run 6x CR123 primaries in a 2S3P 6v configuration in an emergency?
For 8.4 volt operation, 2x26500 Megalennium will serve much better with longer run time, less voltage sag and fewer cell to recharge.Even better...What about loading it with 6 IMR 16340 cells. That would put it in the 8.4V range and there are Lumens Factory Incan bulbs for it as well as bi-pin kit Litho bulbs for that lower input voltage too.
It works fine with my upcoming ROP head with 2x26500 M6Hmmm, what kind of resistance is the mcclicky going to see from 6 x IMR cells?
anything that runs on 1 cell should be fine. Did u accidentally place the cells on reverse?
I tried running a LF D36 LED module on this with AW 18650-2600, and it ran fine (specced 3.6V - 13V).
Glad to hear that. Been thinking about getting one of these and maybe using a Nailbender SST-90 direct drive in one of his Clone M3 heads. 3x18650 in parallel should give it the current it needs. :thumbsup:Initially, I used 3 x unprotected Sanyo cells. The tailcap spring got super hot and retarded the spring. The SST-90 didn't like them either. Once I rep.aecd the unprotected cells with AW 2200 18650's, the light functioned as expected. The Clone M3 head matches exceptionally well! Both are glossy. Now I'm on the hunt for a beam diffuser to complete my "Sea Cucumber" look.
I'll take one of Megalennium Parallel version and $149 for:
#09 Megalennium: Price $139 each with installed McClickie switch, and plus $10 for international shipping.
Wang
