I decided to start removing components from the first dead bulb and try to find out what failed. I desoldered all of the active components as well as some of the passive ones and this is what I've found -
(1) 47uf 160v electrolytic capacitor - measured exactly 47uf - tested ok
(2) MJE13003 NPN HV transistors - tested ok
(1) BT169DH SCR - tested ok
(4) GU1M 1000v switching rectifiers - tested ok
I also measured the other surface mount diodes on the board and they all tested ok, and I got continuity on the transformer.
I removed a small coil from the board (added pictures in my
photostream) and it measured open circuit. So I carefully removed the black rubber jacket and found that one wire was broken off at the base. This might have happened when I was pulling the potting compound off the board.
I haven't measured the SM resistors on the board yet and that's going to be difficult. So I still don't know for sure what failed. :thinking:
**More**
I measured the surface mounted resistors today and while some of them were dead on, others measured anywhere from 20-30% lower than their marked value. Not sure if this is contributing to failures but it makes me wonder about the quality of the resistors.
