I got mine today.
Adding to gunga's excellent review-
With two AccuEvolution C cells, mine draws 33mA on low, 220mA on medium, and 1.22A on high.
With one AccuEvolution C cell, mine draws 73mA on low, 215mA on medium, and 2.20mA on high.
Notice the current nearly doubles with the single cell. You still get very nearly the same amount of light on high with one cell as with 2. That's not how I thought the light was going to work, but I like it. I can't really see any difference in the output of the light between one cell and two. That's good news for those of you who like the looks of this light in it's stubby configuration; you get the same light at the cost of runtime.
I'll get out my light meter later and measure the actual light output with each cell configuration.
I have tested my AccuEvolution C cells with a CBA II and they run right at 4.6Ah. So, a
rough approximation of runtime using 2 cells would be 139 hours on low, 21 hours on medium, and 3.7 hours on high. Using one cell would get about 63 hours on low, 21.3 hours on medium, and about 2.1 hours on high.
My light does produce a very low level, high pitch regulator inductor whine on low and medium, but is silent on high.
This light is extremely mod friendly:thumbsup: It's very easy to take apart. The pill has a large shoulder that screws down against a big fat chunk of aluminum so heatsinking should be outstanding. This light is just begging for an MC-E emitter
Gunga's description of the beam was dead on. It has a really tight hotspot with a huge, but fairly weak spill beam. Very much like an LED maglite.
Just the opposite of how this very same reflector looks in the D-Mini EX, MC-E light. In that light, the beam has a wide (although very bright) hotspot and a huge, very bright, perfect spill beam.
Did I mention that this light is just begging for an MC-E emitter
