I wonder if anyone can help here.
I have set myself up a test rig which has 4 amc 7135 circuit boards on it, one with one 7135, one with two, one with 3 and another with 4.
The Vdd to the 7135's is through a dip switch which allows me to select any number of 7135's from 1 to 10.
It has been quite instructive in comparing the Vf curve of actual XML leds with manufactures spec and for calculaing the internal resistance of batteries.
I have now started to learn about PICAXE chips, thinking to use pwm and my own interface.
To experiment I wrote a progamme which ramps the pwm up and down in response to two push buttons.
I connected the pwm input to the board, selected the single 7135 and everthing performed as I expected.
However if I select any of the multiple 7135 boards, I just get a very weak output, the led is blue and barely lit, which pulses at a clearly visible rate, just 3 or 4 times per second.
Can anyone tell me what is going on? - and how to fix it?
Rod
Rod
