Tom, many thanks for your post on the Pink Panther! Sounds like you're having lots of fun with it so far... oops, I mean, getting lots of value out of your serious, precision work instrument.
[size=+1]Project-M BuildAssist Checklist, Version 1![/size]
While answering a fellow CPFer via PM, it occurred to me that some sort of checklist might help folks get their hands around specifically what sort of build they might want... hopefully it will help both customer and me to be on the same page as far as where to expend the most energy in designing their light. I'm honestly not sure if I've got it right yet, but here's a start... :thinking:
1. What size does this light need to be? Is that a firm requirement, or your ideal scenario? How much of an issue would it be to build something of a slightly different size than the ideal?
2. Which head needs to be used? Either a specific head, or an example of how big. Is this a specific requirement or the ideal... if the latter, how much of an issue would it be to build something using a little smaller or larger head?
3. What sort of output are you looking for in terms of minimum and/or maximum?
4. What battery configuration would be most important?
5. What other battery configurations would you need to support, in order of importance? Are these must-have configurations or ones you'd like to have, but maybe don't absolutely need?
6. What are your budget constraints?
7. Please rank these from most important to least important: multi-brightness capability; ability to run with the widest-possible variety of battery configurations; maximal operating efficiency.
8. Are you willing to limit the potential brightness of your light to make it more stable (able to run continuously from start to finish with no heat issues, ability to operate on badly depleted cells, etc.)... or would you prefer to go for the brightest thing possible at the cost of it possibly only being able to run for 15-20 minutes or so at a time?
