Hello. This is my first post here. I am desperate to find a good EDC light for the criteria provided below, and, as someone with very little experience in this realm, I would like your advice. I have filled in the following, and am happy to provide additional information.
I will be mail-ordering or buying online, so this doesn't matter. (I live in the UK, and would like to order from someone reputable (Heinnie Haynes, Amazon etc)
2) Budget: An easy question, but you may change your mind after answering the rest!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Less than £150. ($235 in your money I believe)
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Holster carry. I want to EDC it, but don't mind weight or size within reason
5) Emitter/Light source:
I don't know. I don't care what light source, just that It does the job I want it to do
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I don't mind, but AA, AAA and Surefire 123As are all a good idea, as I can get, carry and store them easily
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to walk around an unlit rural area (50-150 lumens).
As many as possible. I want it to be capable of getting an attacker to reconsider their course of action or clearly illuminate an emergency situation.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
If my light runs on the batteries stated above, I will toss a PowerPax battery caddy into a pocket at all times, so very high output, short runtime is good for me
Critical (Police, Fire, Search & Rescue, Caving, Survival).
I work on a farm, and have seen everything but the most reliable/durable items fail in such a use, so I want real hell-and-back reliability.
12) Switch Type and location (choose all that apply):
I want a tail mounted switch (found on the majority of today's high end lights).
Other, please specify
The tail mounted switch on the SureFire G2, for example, appeals to me (simple on/off, lock out), and holding torches with my thumb on the base suits me, but I'm not too fussy
A simple on-off with only one output level is fine for me. I want it to be very simple, so high/off would be ideal
14)Material/Finish/Coating
I don't care. If I can get a lightweight plastic torch that still has to-hell-and-back reliability that's all good.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Holster. I want my light to come with a holster or for me to easily get one, preferably closed top nylon with stud or velcro closure
Wrist/Neck Lanyard or lanyard loop if possible.
Crenelated bezel Would be a big plus
Thanks in advance, and sorry If I've done anything wrong, HEUTE
3) Format:
6) Manufacturer:
