OK I did my first LED mod project and I was successful ... with modding my older 2010 Rayovac Xtreme lantern. The new 2012 Rayovac Xtreme lantern I got in the mail I can't get the damn LED off. But more on that later.
I took pictures which I will upload later. In short I would say the XPG-R5 neutral white is about 25% brighter than the latest stock Rayovac Xtreme lantern tripple LED setup. The neutral white LED color rendition is pleasing to the eye and the purplish blue color of the Rayovac is pretty nasty. My older 2010 model of my Rayovac which I modded actually had a pretty neutral color renditon, stock, to begin with. I did not take pictures or do a comparison but I would say the neutral XPG is only slighty more neutral than the old setup. My new Rayovac has the same tripple LED setup as the old, but the color is much more bluish purple. NASTY! I did my comparison with the older modded lantern and the newest Rayovac lantern. I did my tests all on the highest setting of the lanterns. I would say the neutral LED color is excellent, and going with anything warm would be too yellow. But it's all opinion I guess.
However, after doing a 20 minute test standing up, and a 20 minute test upside down, my modded neutral XPG lantern heatsink gets hot each time while the stock Rayovac heatsink gets warm. I took the lantern apart after each 20 minute test and the heatsink was hot both times to the touch. Not absolutely burn yourself hot, but it was still hot. The stock 2012 lantern had the heatsink just warm to the touch each time.
First off I will say this mod is pretty easy. I took the three screws out that hold the lantern compartment together. I mixed the two Arctic Silver compounds together in a 1 to 1 ratio like the directions say, on aluminum foil, and quickly applied them between the stock heatsink and the penny, and between the penny and the XPG LED. I let it sit for an hour and half. It was hard to the touch and my fingernail would barely cause a mark, which is what the directions said. I would say there's enough compount in those tubes to mod at least 10 lanterns, if you wanted to know.
I took a pre 1982 penny which was composed mostly of copper (post 1982 pennies are made of mostly other metals) I think the threshhold year was 1982 I read on the internet, but you should double check on the internet to be sure. I used a 1968 and 1974 penny. One penny for each lantern. I filed down each side of the penny till you couldn't really tell it was a penny anymore. I used one of those long metal filers you can get at home depot. It probably took 45 minutes to file it down completely.
There is a hole in the center of the stock heatsink and I wanted the LED to be touching a heatsink 100% so I decided to use a penny between the LED and the heatsink.
After an hour and a half of drying for the compound, I used a $15 soldering iron I got at Home Depot today to solder the postive and negative ends with the stock lantern wires. Loaded my eneloops in the ebay 2AA to D cell adapters (I only loaded one eneloop in each adapter though for the test) and that's how I conducted my tests with both lanterns.
I did test both LEDs when I got them. I tried just one battery but it did not work. Two batteries did work. I used a Fenix LD20 tube to put both Eneloops in and used old speaker wire to wire up the test setup. Both worked obviously.
