SilverFox
Hello Dabigkahuna,
Welcome to CPF.
I use a Vanson charger and have been pleased with its performance.
The only problem comes when charging high capacity D cells. The charger has a timer shut off that will stop the charge before the cells are completely charged. My work around is to unplug the charger half way through the charge cycle. This resets the clock and the cells completely charge. By the way, I am referring to 9500 mAh D cells. It has no problems with AAA, AA, or C cells (so far until their capacity reaches that level...).
NiMh chemistry has a self discharge rate of about 1% per day. This means that if you let the batteries set on a shelf they would end up at about 30% of full charge in 120 days. The self discharge rate varies as the cell ages, so this is just a rough guideline. I suggest recharging NiMh cells at least every 6 months. Most people recharge their cells more frequently.
Tom
Welcome to CPF.
Tom
