I received the Nitecore NH25UL from Nitecore for the review.
The NU25UL is an ultralight Headlamp designated for the outdoor activities, such as hiking and trail running. Compared to the regular NU25, the UL features an elastic cable instead of the classic elastic band typical of headlamps. The NU25L has a max rated output of 400 lumens, and features 2 main emitters with their own TIR Optic, in order to generate a flood beam and a focused beam, as well as an independent red LED. Both main emitters can be used independently from the other, with their own levels. The NU25UL is powered by an integrated li-ion rechargeable battery with a capacity of 650mAh, rechargeable via the USB-C port.
The NU25UL comes in this box.
The content of the Box: the NU25UL, USB-C charging cable and the manual.
Here you can see the front of the NU25UL, with the 2 main emitters clearly distinct, and their own optic.
Let's peel away the protective cover.
Here you can see the very compact nature of the NU25UL: compared to a small BIC lighter and a standard size Clipper lighter. The light weights 46.6 grams, including the headband cable; and measures 60mm x 33mm x 26mm.
The back of the headlamp, that rests on your forehead, has a foam insert to make it wear more comfortably and avoid slipping. You can also see the loops that hold the headband cables.
On the back there's model number, the battery capacity indicated, and you can see the rotating mechanism.
On the side there's the USB-C port for charging the battery, and on it the IP66 rating.
The headband cable is elastic and has some stiffness to it, is both glow in the dark as well light reflective.
There's a stopper to adjust the length of the headband elastic cable.
On the top part of the NU25UL you have the 2 switches, as well as a 4 step blue LED battery indicator.
Here's the UI
Beamshots
Thanks for reading.
Here's the UI
Beamshots
Thanks for reading.
